Dirt wheels has an add for a Redline Revolt if you have not seen or heard of this thing it's pretty cool they have a 72hp model and a turbo model with 100+ hp. single seater & they have a side by side. I checked out the videos after seening the add.
    • By TomJulio
    • By TomJulio
    • By treycotiii
      Looking for the best options. I primarily use the machine for snow removal and yard cart pulling.
    • By joezee13
    • By middlebrookgt
