96 polaris carb.grrrrrrrrrrrrrrrrrrrrrrr
By marlon smith
By BillR94
By BillR94
Thank you for your time
Bill
By Jason39
I’m having a issue with my choke when its on it runs fine when I cut the choke off the atv cuts off went to take the carburetor off and saw the choke plunger broke at the nut to screw it in could this be my issue? Do I just need to buy a plunger kit and put it on? I took the carburetor off and cleaned both jets anyway just to make sure and it’s still having issues staying on
