Similar Tagged Content
By Guythis448
Looking for help on wiring up stock wiring harness specifically for a '88 Honda TRX 300
If anyone could drop a link or send me a PM it would be much appreciated
By Danny Ouellette
Hey guys! I only need a couple think from the machine. Front bumper is #1. The other is the front plastics in grey. Used is fine as long as there is no cracks.
Thanks,
Danny
By Martin Carrière
Recently bought my BB. Everything works great. Only thing is, each time I put it in reverse, it either starts to rev high and start moving without giving it gas or I'll give it a bit of gas and let go and it will still rev at the same rpm or higher and keep moving. Doesn't do it for high or low.
By dyyjrr9
I just got a 1991 Yamaha Moto 4 for my son and I am looking for a service repair manual. I know that the timing chain needs replaced.
By suthernboy60
Since I am not much of a mechanic simple things confuse me. How do you remove the old brake cable for the pedal brake from the frame? Thought I could just pry it out but no luck and not much room to work. Any help is appreciated.
Similar Topics
By jake Stillman
Hello I am new to this forum and lt80s I have an 87 that has burned up 3 coil/cdi combos my question is can I out the newer set up on it and if so how do I do it I know they have different number of wires going to the cdi mine only has 2 please help
By Blenderite
Hello guys! New to the forum, and fairly new to ATVs. I've driven them, but never owned one. Now I do own one. Just picked it up today. It's a 1999 Yamaha Big Bear 350. It's been through some stuff. The guy I got it from told me the previous owner removed the front diff because he didn't want to replace the half shaft. So it's 2wd, even though it's supposed to be 4x4. Lovely. I can deal with that for now.
More importantly, I need to get it running. The carb needs to be rebuilt. The guy I got it from said he sprayed it all out and it still didn't work. I'm concerned he might have damaged it or not put all the parts back. I was looking at a replacement carb, and the OEM parts is $600. I'd rather not spend $600 if there are any other options. I have seen carbs on Amazon and eBay that are in the $40 - $100 range that say they fit. Anyone have experience with these? I'm going to get a rebuild kit for the current carb just to make sure that won't fix it.
Thats the first thing with it. Secondly, it was completely rewired. I need to find a original wiring diagram so I can put it back how it was, with a key and all. Currently it's wired with just a rocker switch. Any sources for a service manual that would include wiring diagrams?
Thirdly, is the Big Bear 350 a good atv? I picked it up for $700. It does start and run when you spray starting fluid into the air intake, so I am not concerned about the engine being bad. I plan to use it for the farm, running around and carrying things with it like minerals and feed and such. Not really for mudding and things like that. How good is the 99 350?
I am certain I will have more questions as I examine it more, but that's all for now. Thanks in advance for the assistance!
-Blenderite
By Arizona
Just a couple of things since i get various atvs.
They always need seat cover and always need oil and other minor items.
My question is Do you buy any specific motor oil for them, i heard you must get atv oil or will mess up the clutch.
Not sure if correct but didnt want to find out hard way. Is there a cheaper oil or can you use regular motor oil?
Next they always need a new seat cover, any good places to buy bulk or cheap vinyl to re do the seats with out spending
30-50 dollars on a specific cover?
whats you go to places for parts, i use amazon, ebay any others that offer a good deal?
that goes for hard parts or just cables and or clips, wiring, bolts etc no wrong answer here.
always looking for new ways to find parts for the older atvs. TIA Az
By Lellwyn Griffin
Both the red wire and the blue have power with out the start button being pushed. Which one should have power? When I hooked up a positive and a negative to the starter relay it started.
By edb6969
View File 1999-Later Honda TRX400EX Carb/Cable Removal
1999 - Later Honda TRX400EX Carb/Cable Removal Supplement
Submitter edb6969 Submitted 11/02/2020 Category Honda ATV
