2009 Can Am RS SM5 (Collierville)
By quadcrazy
QUADCRAZY NEEDS YOU!
By colin james
View File 2017-2019 sportsman 450/570 with eps factory service manual
This is the factory service manual for the 2017-2019 factory service manual for the sportsman 450/570 with electronic power steering
Submitter colin james Submitted 09/06/2018 Category Polaris ATV
By davefrombc
It would be helpful at times to have a button where we could cont the Admin. to make some changes to our posts.
By mga
So, i go to change the oil in my 2k Y 400 BB and, without reading what types of oil to use, i just put in 10w-40 motor oil.....then i decided to read exactly what type of oil i should be using. Apparently, the ATV oil is designed to also work with the clutch..lol...which is probably why i was having a few issues going into the gears, or, maybe losing 1st gear going down a hill. Ok, now that i got educated i bought like 6 quarts of the "special" oil required.
Now, my second issue is it was hard to start for some reason. Usually it fires right up. So, once started i brought it up to the garage and removed the seat, thinking maybe the battery was weak from sitting. Nope...12.5 volts, but.....a mouse decided to build his nest right on top of the battery. I cleaned that all out, but, when i went to start it, the solenoid clicks and the starter just spins. UGH. One thing after another. No wires were chewed thankfully. Just kind weird the starter would do that all of a sudden when i messed with the oil.
Do i need to pull the starter now and check the bendix thing? It spens real nice, it just won't engage. The wrong oil wouldn't do that...would it?
