I've got a 360 Prairie 4x4 and the 2wd/4wd light is flashing at 1 second intervals. The manual says the K-EBC actuator is malfunctioning. Is this a hard fix or do I have to take it in to a dealer. Also if it is something I can change, where can I order the part aside from going thru a dealer? I've checked online and can't seem to find anything related to the engine brake. Thanks
I have the 02 650 prairie the K-ebc is on the right side engine cover. The light could mean the cvt belt needs service. A few question is your quad shifting from 2wd to 4wd ok & 4wd back to 2wd, do you have squealing on take off or when climbing hills & last when going down a hill if you blip the throttle you should feel the kebc working. Their is away to reset it I just don't remember the web site I found it on I will try and find it and post it on here. I think it should be the same as my 650 as far as the reset.
  • 9 years later...
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
      Sportsman 1000 wiring diagram
