Similar Tagged Content
By Ellery Zandt
Does anyone have a redcat 250 or falcon 250cc that they can share where the two vacuum lines on the carburetor that you run antifreeze through I honestly have no idea where the lines are suppose to go to circulate the antifreeze.
Any help is greatly appreciated.
By BosoxBruce
Recently I noticed gas leaking from under the gas tank on my 2005 250 2x4. As I looked closer it appears to be leaking from the shut off valve under the tank. It's the valve with the handle that can be turned to open, close or reserve. Can this part be replaced? Thank you.
By Derick Joel Smith Trimmings
Buying a Baja 250 tomorrow for 600 bucks, needs nothing but a wheel bearing, i already know Baja is an off brand crappier. Manufacturer, but does anyone have any tips or knowledge of these bikes?
By fatfarmboy
Just bought (Tue. evening) an '89 Suzuki 250 4wd that has been sitting out the last 5 yrs. It's complete, including the shift knobs, battery cover, and headlights. It has the optional cooling fan on it (probly stuck - didn't check), and the engine isn't locked up. Plastic looks good and isnt cracked. Racks aren't bent up. Shift lever works, the foot brake moves (needs oil - have to pull it up by hand), and there's black oil and no water in the engine sight glass. Guy was asking $125 and gladly took $100 for it. Anxious to get started on bringing it back to life. Been wanting one of these for years. As soon as I can get to it (working on a junky "Jackel" right now - Chinese Yamaha Timberwolf). I'm going to pull the tank off it and clean it, clean & possibly rebuild carb, put in new plug, and a battery, then see what happens. If nothing, will keep going until it runs. Feel free to respond if you want to, I'm mainly just excited and wanted to tell somebody.
By Flanstone
I just bought two 1985 TRX250's from my father-in-law. One runs great, the other not so much. The one is having issues with the shifter. The shifter seems to be resting lower than normal. When I press the shifter downward, it just pops back up. Any thougjts as to what the issue might be?
Similar Topics
By AKMichael
Hello All,
I have a 1999 Yamaha Big Bear 350 4x4 trying to get fixed up so my grandson can go out in the woods with me.
We have owned it over 10 years. It got harder to start, until it finally would not. Replaced the carb. Right afterwards, it started and ran nicely, but after turning it off, would not restart. Tonight I used starting fluid and ran, then died. Adjusted the idle up a little, used more starting fluid and ran great. It idled about 15 minutes. Turned it off, and restarted. Ran it around the yard about 5 minutes. Turned it off, and would not restart.
Any ideas or suggestions would be greatly appreciated!
Thank you.
By Susan Makowski-DeGraw
My quad runs, it starts up runs for about 10 minutes and then it dies if you let it sit for 10 minutes it’ll start back up ride for another 10 minutes and then die again, trying to figure out why it keeps stalling
By oxidized_black
1985 - 1990 Suzuki LT230 & LT250 Service Manual
https://www.quadcrazy.com/files/file/532-1985-90-suzuki-quadrunner-lt230-service-manual/
1987 - 1998 Suzuki Quad Runner 250 & King Quad 280 Service Manual
https://www.quadcrazy.com/files/file/268-quad-runner-250-king-quad-1987-1998-service-manual/
1987 - 2006 Suzuki LT80 Service Manual
https://www.quadcrazy.com/files/file/89-1987-2006-suzuki-lt80-service-manual/
1987 Suzuki LT500R Quadzilla Service Manual
1988 - 1992 Suzuki LT250R Porting Instruction
https://www.quadcrazy.com/files/file/90-1988-1992-suzuki-lt250r-porting-instructions-manual/
1988 - 1992 Suzuki LT250R Quadracer Service Manual
https://www.quadcrazy.com/files/file/91-1988-1992-suzuki-lt250r-quadracer-service-manual/
1988 - 1992 Suzuki LT250R Tuning Guide Instruction
https://www.quadcrazy.com/files/file/92-1988-1992-suzuki-lt250r-tuning-guide-instructions/
1999 - 2004 Suzuki King Quad 300 Service Manual
2002 - 2007 Suzuki 500LTA Service Manual
2002 - 2009 Suzuki LTF250 Ozark Service Manual
https://www.quadcrazy.com/files/file/94-2002-2009-suzuki-ltf250-ozark-service-manual/
2003 Suzuki LTZ400 Service Manual
2006 Suzuki 50LTZ Quad Sport Service Manual
2004 Suzuki 250LTZ Quad Sport Service Manual
2005 Suzuki LTA700 King Quad Service Manual
2007 Suzuki 90LTZ Quad Sport Service Manual
https://www.quadcrazy.com/files/file/97-2007-suzuki-90ltz-quadsport-service-manualpdf/
2008 Suzuki 400FLTF King Quad Service Manual
https://www.quadcrazy.com/files/file/98-2008-suzuki-400fltf-kingquad-service-manual/
2008 Suzuki 750 King Quad Service Manual
https://www.quadcrazy.com/files/file/99-2008-suzuki-750-kingquad-service-manual/
2009 Suzuki 400LTZ Quad Sport Service Manual
https://www.quadcrazy.com/files/file/100-2009-suzuki-400ltz-quadsport-service-manual/
ALSO CHECK SUZUKI ATV SERVICE MANUAL DOWNLOADS
Please visit the downloads section for ATV manuals at https://www.quadcrazy.com/files/
Also available at:
By SirMaxwell
Any luck with manuals?
I need a carb in the owrst way and am have gone down a lot of rabbit holes (over 90 tabs and counting). Factory calls for a Mikuni BST34/1 (I think, but need to check manual). I don't care what or who makes the carb, just need a basic reliable carb. No Racing etc, just puttering. I currently only have the cable with the round slide attached.
Don't care if its round if I know what other parts to get to make it all function.
Thanks for help, and listening, gonna go chase more rabbits I guess.
Max
By Edgar5656
Looking for a carb for 87 moto4 200. Just bought the machine and it’s got a Chinese one that’s not working right even after I cleaned it out. Looking for the original mikuni vm22sf.
