I have a 1987 yamaha moto 4 225. Trying to start it and i am running into a problem. When i go to crank it, i turn the key on and the neutral light will not come on. I try to start it and nothing. However, when the lever is back in reverse, the reverse light comes on and also the head lights work.
I know that the neutral light bulb is not out.
Any Ideas??
i had the same problem with my big bear, it turned out to be a wire, like 2 strands and wasn't making a good enough contact. my safety switch is located on the foot shift side, on the top of the motor/transmission. my light never went on before i fixed it too ...
    • By realpilot
    • By cfherrman
    • By OldATVowner
    • By cruteg8
      Does anyone know  the orientation of the bell crank for scrambler 400 2x4 it was not hooked up when I bought quad the way  i put it high goes into reverse and vise versa I flipped it 180 but that put  the shift rod at big angle and it just kinda grinds into gears so dnt think that is right either pretty sure it has to be the exact orientation and the rod adjusted accordingly but I cant seem to find it anyone knows please help
    • By flyinbrian365
      Factory service manual
