I have a raptor 660 with a carb kit i put in it, it is running like sh** it will sputter and blubber and sh** i had it running good until i would grab 5th and try to go and it would just wana lay down...Can some one tell me a good starting point on the settings for the main jet screws and the needles for each carb left and right...And which size het goes in what side..i have a 140,145, and a 95,..It has a slip on pipe, also has a K&N filter...SOMEONE PLEASE HELP!!!
i got it running good now, i have the 145 and 95 in the left carb, and a 140 in the right carb...I got it running good until i grab 5th and try to go good then it wants to blubber and sh** the needle is on the 2nd one where should i go???
    • By Jdeaton011989
    • By Gtc4d
      Thanks.
      Todd
    • By jordan_ATV
    • By alexwv1863
      I'm currently working on an 04 Suzuki Eiger 400 and ran into some issues. Main issue being it's really hard to start. Once I get it started, it runs bad. Sounds like it's missing, which I'm pretty sure is an idle issue. It's not my 4 wheeler. I'm working on it for a buddy. Someone started working on the original carb and 2 jets were missing when I got it to work on.
      So, I ordered a new carb. To get it to run, I had to adjust the throttle screw on the handle bar almost all of the way out. Even doing that, it still sounds like it's bogging down and missing.
      I did put a gas filter on it, which I'm questioning whether or not that's the issue and it's not getting enough gas like it should. The petcock only has an On, Reserve, and Prime option. It also has 2 ports. I guess I have the hoses hooked up right. There's no way to shut the gas off completely, and also it looks like there's no gas getting thru unless I run it on Prime. Reserve drips gas. I'm going to take it apart today and clean it. I'm also going to take the jets I need out of the new carb and put in the old one.
      I don't know what all this person did you the 4 wheeler before I got it. There's odds and ends missing that I've noticed so far. What else can I try or look for? What could be the gas issue with the carb and petcock? The carb was completely off the bike except hanging onto the throttle cable. The diagram I found for the carb doesn't help me with hose placements. Any help, or questions would be appreciated. I can attach photos if it would be of help.
    • By PupATV
      -PupATV
