so i just got a yamaha warrior 6 speed from a i cannot get it out of "neutral" the reverse light is also on.... when i move the shifter the gears still click any ideas on how to fix this would be great thank you!
Create an account
Register a new account
Sign in
Sign In Now
    • By Need-help-with-quads
      So my moto 4 is smoking white smoke and when I go to first gear and get about half throttle there’s no power and it sounds like it’s bogging
    • By Frank Angerano
      I’m looking for any member that may be familiar with the neutral safety switch on this bike.
      I picked up a bayou 220 that I found sitting in a shed. Nice looking bike the guy said it would not start one day and put it away and never touched it again.
      So it turns out the neutral safety switch is bad.  I jumped it out and the bike fired up and runs good.
      I’m more then capable of the work in changing it but this thing is buried pretty good. I’m curious if anyone has done the switch replacement before?
      I attached some pics to see.
      picture 1 is the side view you can see the green and red wires going into the cover.
      Pic 2 shows looking down on the drive shaft coming out of that cover.  That is not a simple cover you just pull off.
      Im wondering how deep and how much sh** has to come off like the drive shaft etc for this switch  to be replaced.
      So if any of the QC members have done this switch I’m looking for any input with regard to changing it.
      Thanks.
    • By heath
    • By Wam12905
      Hey all!
      I recently acquired an 02 big bear 400 this past summer, carb on it was shot to sh** (pics attached) so my father recommended I just buy a new one off amazon. I purchased the first one that came up as compatible and once it came in, I bolted it in and it fired right up with no noticeable issues. Once I got to the trails with it I realized that on any un-level ground, there's little power output. I checked with 3 different local shops and they all refused to work on tuning up off brand carbs because of how terrible they are. One shop had a motorcycle in with an aftermarket carb and the mechanic said that that would be me if I brought my big bear in. Whoever owned the motorcycle and needed their aftermarket carb tuned up had racked up the bill to nearly $1500. Needless to say he made it clearly obvious that putting any amount of money into an aftermarket carb is not worth it. Now that I've learned all of this, I'm wishing I didn't toss the old carb for a $30 amazon one. In light of this minor f-up does anybody have any recommendations for high quality carbs for my vehicle? I've also attached pictures of the old carb and its condition for your curiosity, although its current condition is likely 6 feet under in a landfill somewhere.
      https://www.ebay.com/itm/283488113569?_skw=Big+Bear+400+Carburetor+Oem&epid=10042848409&itmmeta=01JCDWCTMJX5GBC407RF2PPVDD&hash=item42013553a1:g:INUAAOSwn8llquIL&itmprp=enc%3AAQAJAAABAHoV3kP08IDx%2BKZ9MfhVJKkIMhqd%2Fye0vA0YMR5DUzMoCLl0F9GPNRfuAJKaylVqqyVrZCBJVvXQaPrlosjt%2FZnIHyIRPuGiIbxC9o%2B02UqGA4YqXDyyH4bVebnTPz8P5Elg76CvLdu3KyZgwpgpSeYJK2IOWtlo9vtTld7RVjqPwSv1VF26v6kyXGesAB%2BA%2BCHsj3OnqNrHMyKCBuDMSSvUWvOfq%2BKsZKqyHR7yduef%2BHBlXvfiyRJPThHr7Ge9n%2BHBbuxRCb4oF7%2Fp8oZsvajHy9YDitFRfNJeeAssYbgXuhAc7AVvUZZ2YxKW9GzDdxltLMap8orKJtr%2BIk0SRGQ%3D|tkp%3ABFBMsqqzvONk
      I found this one on EBAY that advertises as a genuine OEM part for a fraction of the $650 that they're normally worth. Any help would be greatly appreciated, thanks!
