Similar Tagged Content
By Ajmboy
View File 2003 Scrambler 50 Predator 90 Scrambler 90 Sportsman 90 Service manual
2003 Scrambler 50, Predator 90, Scrambler 90, Sportsman 90
SERVICE MANUAL
Submitter Ajmboy Submitted 05/28/2017 Category Polaris ATV
By atvfarm
Ok Im new here. I was given a cougar 250 and i put a new carb on it and it will idle great but anything above low rpms spits and sputters. also is this thing suppose to have a fuel pump or just gravity feed from petcock?
By atvfarm
By gbforever2001
Hey all, new to the forum. This quad I picked up for pretty cheap has no markings, labels or anything, need to get some support information about it if anyone can help. Thanks!
Similar Topics
By SirMaxwell
Any luck with manuals?
I need a carb in the owrst way and am have gone down a lot of rabbit holes (over 90 tabs and counting). Factory calls for a Mikuni BST34/1 (I think, but need to check manual). I don't care what or who makes the carb, just need a basic reliable carb. No Racing etc, just puttering. I currently only have the cable with the round slide attached.
Don't care if its round if I know what other parts to get to make it all function.
Thanks for help, and listening, gonna go chase more rabbits I guess.
Max
By Curtis01
OK, sooo I finally did the old skid plate and screen removal to clean out my oil sump during an oil change... This bike only has a couple thousand miles on it. Runs like a top still... Very few issues over the years after buying it used.
But boy I wasn't expecting to see this! Piece of a circlip, stuck up in the screen, and a another shard of metal and maybe a piece of gasket material. Nothing in the oil but that... Pristine otherwise, and still runs like a top. Always has.
Soooo, is it a wrist pin clip? That's the only thing I can think of like this that could end up in there. But definitely wanted to throw it out to guys that have seen the innerds of these more than I have.
The valves on this thing are still within the factory spec even. Been a really good lil workhorse...
Any other ideas?
By KDawgFPC
I have a 2004 Kawasaki KLF300. I’m not sure What is the black/yellow, brown, and red wire wrapped together in the wire hornets of a klf300. I got it used and notice some wires not connected. They are located in the front area
The reason why I am asking because I’m having issues with it firing up. I cleaned the carb put new spark plugs and gas.
By tnhomestead
Can anyone id this polaris? Cant find a serial number and not sure where to look! Need to figure out how to adjust the shifter as it's a bear, and pretty near zero pressure on rear brake pedal sinks it to the floor. Thanks! Was redoing a lakota and got a buyer for it and a hope a deal on this, was 1200 with all new cv joints and bushings and a few other items.
By Johnnyhorsepower
I finally found an awsome app for your phone that shows you on a map all the trails near your location. You can read or add reviews, look at picts...etc
Its called: atv escape
John
