Hey there everyone.
Father in law picked up a used 2000 BB400 4x2 - motor runs well, no smoking. Little cold natured, but starts easy enough on full choke, and as it warms up you can back the choke off to a normal idle. Not uncommon for older carbed bikes/quads.
but - cold or hot, this thing is sometimes a real pain to get into reverse or 1st without rocking it back and forth a good bit. as it warms up, again it acts better,but doesn't get perfect.
When moving,it shifts up and down smoothly and accurately with no signs of clutch slipping.
Oil looks good and clean.
I see the clutch adjustment on the left side crankcase - but before I go screwing with anything, I'd like some other's opinions on what I might do to make the engagement easier.
thanks,
Chris
      Best ATV for Older Riders
      Polaris Sportsman 570 EPS
      Best Reliable ATV for Seniors
      Honda FourTrax Rancher EPS
      Best Features
      Best Premium Comfort ATV
      Can-Am Outlander MAX
      Standout Comfort Features
      Best ATV for Easy Handling
      Suzuki KingQuad 500AXi
      Why Older Riders Like It
      Yamaha Grizzly 700 EPS
      Best Features
      Arctic Cat Alterra 600 TRV
      Key Advantages
      Electric Power Steering (EPS)
      Automatic Transmission
      Lower Seat Height
      Two-Up Models
      Hand Warmers and Heated Grips
      Adjustable Suspension
      Buying Too Much Power
      Ignoring EPS
      Choosing Aggressive Tires
      For most mature riders:
      Final Thoughts
    • By BillR94
      Thank you for your time
      Bill
    • By HHurks
      Hi to all
      Newbie here. Not new to ATVs. Look forward to learning a few new things and hope to maybe help some too.
    • By Jason39
      I’m having a issue with my choke when its on it runs fine when I cut the choke off the atv cuts off went to take the carburetor off and saw the choke plunger broke at the nut to screw it in could this be my issue? Do I just need to buy a plunger kit and put it on? I took the carburetor off and cleaned both jets anyway just to make sure and it’s still having issues staying on
