Yes, Ole Farts can still have fun
Went to Lakeview ATV park in Solon, Iowa over the weekend.
Had a blast but Monday clean up, not so much. Mud not a big deal but mud mixed with grass wrapped around every thing is a bi***. Should've probably hit a car wash on the way home. Had to remove the wheels to get her clean. I think Im done until next summer
Got stuck once winched it out went about 5' and was stuck again. Got some good video.
I think tomorrow I will see if I can't edit over 2 hrs into 15-20 minutes and put it up on youtube next few days
Wish I would have got a better still.
Here is a
I uploaded to Youtube
Took a pretty hard hit about 12:45 mark. Machine went one way, wheels went the other.
Edited by sidmabb
    • By jay41198
    • By mehim
    • By TravisCr
    • By hardcastle
    • By Topendcol
      First issue was fuel pump wont start once ignition has been turned on. Replaced the pump as I had one on hand, than noticed no power so replaced the fuel pump relay as that was were i traced the power to. Still nothing so further inspection looks like signal is coming from the PCM (FLR B20) but not switching the the brown wire to the fuel pump. Ive checked the operation of the bank angle sensor and it appears operational. Fuses and wiring all appear OK. The engine stop relay also tests OK. Ive been through the repair manual and diagrams but to no avail. Fully stumped, any tips would be helpful. Thanks
      Col
