if it backfires, it's getting too much air. check the intake boot from the carb to the motor for cracks ...
if you have some quick start, spray some around the boot, if it revs up, it's cracked ...
if not, adjust your fuel/air screw ...
did check boot and did spray around all areas of the carb head hook up
cleaned the crap out of carb cleaner than most new ones
been rebuilding carbs for many years
soaked it sprayed it and blew everything with air
major confused on this one
why I'm here asking questions
he should have never let it sit for 2 years with this new crappy gas :(
I looked into the carb while running seems to as you try to rev it up sems as though it's spitting compression back into the carb? as you try to open the throttle~~~
also no adjustment screws on the carb other than idle
a few got one running to the so called fuel pump
a few over flow tubes
miss the older ones 2 lines-- gas in-- over flow in case ya flip it
any clues on this he is selling it for $1300 but the guy wants it to run right
knowing him when it's running right he will keep it
he might try to out run my Honda 350 full time 4x4
on a flat out haul maybe-- in the woods he's toast :)
i'm not the best with carbs, best i can do is up a manual for your viewing pleasure.
cheriah, a member here, has a polaris and is great with carbs. she would be more than happy to answer any question you have if you message her here ...
thanks for your input and the manual will have to get to another puter to see it- no pdf on this one :( not sure at this point it's carb issues~~ if you see my point--might be fuel pump issues? line -vaccum- could be a firing problem
maybe even a blocked exhaust--mouse nest~ seen a lot of crazy stuff in my years
as have you- we are about the same age so it seems on the info on here
good typing at ya bro
maybe someone else has had these problems and will chime in
many thanks ~~~~
Edited by jr32560
Backfiring
G ETC or speed limiter system
malfunction
G Fouled spark plug or incorrect plug or
plug gap
G Carburetion faulty - lean condition
G Intake / Exhaust system air leaks
G Ignition system faulty:
GSpark plug cap cracked/broken
GIgnition coil faulty
GIgnition or kill switch circuit
faulty
GIgnition timing incorrect
GSheared flywheel key
G Poor connections in ignition system
G System wiring wet
G Cam lobe worn or Valve sticking
G Lean condition
Engine Runs But Will Not Idle
G Restricted carburetor pilot system
G Carburetor misadjusted
G Choke not adjusted properly
G Low compression
G Crankcase breather restricted
G Air filter restriction
    • By LashinWheeler
      Any help would be great,
      Thanks!
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
