Similar Tagged Content
By Ajmboy
This is more of an informational fix I wanted to share..
My Grizzly has been getting harder and harder to shift this winter and today was completely stuck and I needed to plow the few inches that came down this morning. First thought...oh no, tranny...but it’s winter and maybe it’s iced up. I pulled off the plastic to see what was going on and indeed I did find the drain tube iced up.
I took the blow dryer out and de-iced it. Quick fix, I never really thought about the shifter drain tube icing up before, shifts like new!
FA04AC3B-4FB0-4764-AFD9-1492F5CC790B.MOV
By Matt Dyche
Can anyone give me guidance on my issue. I have a 02 Grizzly 660 and replaced the wet clutch, primary shaft, one way bearing. Today I was riding since I tested and was driving about 20-25 mph and all of a sudden the tires locked up, heard a screeching sound, and engine died. Didn’t have a clue what was going on, decided to try and restart, engine turned over normal but engine hesitated slightly, started and had to assist with the throttle. It seemed to do this for a minute then seemed to straighten out. Got home, pull clutch cover and test drove to witness clutch operation and everything looks and sounds perfect. Could not duplicate. Please help.
By Guest Fox300exchic
If we had a dollar for every time the question “Which is really faster, the 700 or the 450?” shows up in our inbox, mailbox, or voicemail, we’d be putting this magazine together from a bungalow on a barely inhabited tropical isle named Quadhama.
http://www.quadmagazine.com/quad/features/article/0,24942,1603755,00.html
By dglover1226
I have a 01 raptor and recently had to bore it out to a 686 because it sucked in a bunch of sand. Now I have no torque or power in the first third of the throttle. I am hoping that someone else knows what is going on with it
Similar Topics
By ENG243
Hello
I have a 1994 Kawi Bayou 400 which had been running well until it sat for about a month. I left the carb dry while it was park and the temp had dropped below 0C in this time. Pulled it out last night to go for a ride and it fired up just like it should but noticed when I started to head down the road I could hold it to the bar and it didn't seem to accelerate. Lower gears weren't as noticeable but 4th and 5th it just seemed to have no acceleration and half or full throttle made no difference. if I tried to go into 5th gear with any throttle it would stall. I turned around and just poked home very slow and it seemed to stay running but this was between 15 and 20 km/h max.
I have taken the carb apart and it appears to be clean and nothing stood out on inspection to have dirt or ice. Is there something I should dig more into?
I have checked the plug and it appears to be sooty with easily rubbed off carbon. I plan to get a new plug today and test.
compression with the throttle wide open is 175 psi.
I have opened the drain plug in the exhaust thinking there could be a mouse in the exhaust or something but no difference.
I do find the engine is tickity compared to my 2000 Honda but I am not sure if this is just me looking for issues or if it has always been this way.
If anyone has any insight I would appreciate it.
In the last 6 months I have done new oil and filter ( mystik synthetic)
new Peak RPM CDI
I have noticed the fan comes on more often with the new CDI, could this be a program thing?
Mike
By JacobSlabach
Hey I picked up a pit bike and a foreman for 800 the pit bike was running but the foreman was locked up. Sold the pit bike but when I took the top end off the piston I only found half a piston left. So knowing the rest of the piston was down in the crankcase I knew it had to be pulled and gone thru completely.
to pull the motor I went ahead and pulled the rear end off and unbolted the front diff to pull the drive shafts and pull the motor. Now I have the motor torn down completely and have all the parts of the piston removed. I know the rod and crankshaft is shot (heat discoloration and too much up and down play rod to crankshaft).
***so I’m wondering while I have the motor apart what should I check for? I know this motor died from heat as the oil in the head smelled like popcorn. So what should I check to make sure I fix the issue (overheating I assume) and not just the symptoms (blown up motor lol).
Here’s some pics
By ATVNetwork
news The KingQuad 500 and 750 Power Steering models get plastic utility rack covers.
Suzuki says the snug-fitting covers can aid load securing or be a workstation. View the full article
By jwline
Friday evening went riding, rode for a good hour or so everything was fine. I went to take a short ride to the restroom (less than 100 yds away) and all of the sudden everything flickered and then just died out. Accompanying the problem I noticed the killswitch completely locked up. Once daylight hit took the killswitch apart to find it had shorted out and melted the plastic inside. Has anyone else had anything similar to this and if so what did you do to fix the situation? I have a new killswitch on the way to replace the obvious problem but was wondering could there be a bigger issue at hand. We tested with a voltage meter to make sure everything was still getting power from the battery and as far as we could tell it was.
Any advice/info would be GREATLY appreciated.
Thanks.
