First post! Lets get to business. I picked up an Arctic Cat 400 a few weeks back and I've gotten to the last few repairs before she will be ready to ride.
I'm missing the prop yoke that comes from the gearcase but after checking arcticcatpartshouse.com I noticed the diagram differed from my actually set up. The opposite yoke is actually welded onto a 3 bolt flange for mine but they don't show that on their diagram.
Also I noticed this intense side to side motion from the 4 link suspension. The rear axle has been replaced and the suspension redone but I don' think it was done correctly because it has about 4 inches of side to side play. In my mind it could be one of two things, the link brackets are in the wrong location or the bushing are completely shot.
And my bike is also full time 4x4.... I didn't even know the 400 could come like that lol
Thank you for your time =)
what happens if you go a year or two back or ahead with the diagrams for the proper parts?
it might have been a real chop job if the rear axle was replaced with something different or off another year etc.
alot of full time 4 wheel bikes are out there, seems it's alot less expensive to put a solenoid in and have the convenience of 2 to 4 select ... full time 4 = armstrong steering
    • By tepin
    • By Shorty51
    • By DexKing
      Good day everyone!
      I am pretty new to ATV/UTV/Small engine repairs and would like input on your absolute must-have specialty tools for maintenance and repairs. Aside from the obvious wrenches and sockets, what are some more specialty type tools you use for troubleshooting? I don't plan to open a repair shop or anything, I just do this as a hobby. Looking forward to your responses!
    • By randyoct
      Will the top end of a 400 fit a 366 the price is so much cheaper
    • By middlebrookgt
