Hi
What machine would you recommend ? - Really want a solid machine since I am no mechanic but can perform a early service myself.
Just picked up this 2025 Kodiak 700 esp and was wondering if anyone has any suggestion on up grades i should look into ?? I did a EPI clutch upgrade and put bigger tires on it but want to do more !!
Hello. New guy here. First time 4 wheeler owner. This may have been discussed somewhere but I can’t seem to put in the right words to do a proper search. Hoping someone can help. I have a 2000 Yamaha big bear 400 2WD. There is what appears to be an oil fill hole next to the pull cord. The cap has no dipstick. What fluid goes in that and how do I drain it?
*the other side has a dipstick for the oil. I don’t want to put something in that could cause an issue. Thanks in advance.
