By alexwv1863
I believe the Kawasaki is either an '03 or '04. Green automatic with shifter on the right side. Rear differential was bad, so I replaced it with another. The 4 wheeler rolled in neutral when I parked it in the shop to work on. Took old diff off and replaced it with another one. The diff I put on, turned before I put it on the bike. Once I put it on the bike, the rear end wouldn't move at all. It's like it's stuck in gear. Bike is still in neutral. I've tried rocking the bike while trying to put it in high, won't budge. Can anyone tell me of something to check or try? I haven't opened up the transmission case yet to see what's going on. What should I be looking for?
By DGBear
This thing is stuck in reverse! 2021 Axis with less than 15 hours on it. I cranked it, let it idle for a few minutes and when I put it in reverse the engine died and it won't come out of reverse gear. Any help is appreciated.
By JGou
Have an axis 500 bought from Lowes.. Have had to adjust the shift linkage 1/2 doz times in the last year.. Now the UTV is stuck in neutral.. Seems to shift ok through gears but neutral light never changes, and wont move at all when running.
Only have 13 miles on this 4x4 and have had no other problems... Any help would be greatly appreciated.. Thx, Jay
By anryu451
Rescued this thing from sitting in a warehouse the last two decades. Finally got it to fire, but when I put it into neutral to do so its now stuck in neutral, and wont shift no matter how much pushing, rocking, etc. Even with throttle it wont. Range lever on left side will go from H to L, but not to R, and this makes no difference on it being stuck in neutral.
Any suggestions?
By Gwbarm
My Yamaha Big Bear shifts through all the gears good, goes into reverse smoothly, but when i go to get out of reverse it takes a lot of effort to get it back to first gear, and even then it does not go very smoothly, have to pull up on the pedal really hard, anyone else ever had this problem. Any ideas would be greatly appreciated.
