Finally got the beast to run. However it will not run unless the choke is on the half to full position. After it starts with the choke on, it idles without any rpm change. Nice and smooth. Would appreciate some help.
Thanks for the reply. I actually have three project quads - lf180 - lf160 - lf250. I did a lot of quading in years gone by. But they were much newer than these project quads that I am working on, so I didn't really have to do any rebuilding. I do understand the basics but need help from time to time. Just a question, are there any quad salvage shops in your area. I live just outside of Lethbridge and there is nothing here for parts of older quads? Thanks again. - Mike
alot of times these atv salvage yards are like the car/truck salvage yards going coast to coast with their inventories .... and your could always talk to one and they may give you some info and if someone has a bunch hidden in a barn somewhere ...
kijiji and ebay host alot of parts too
Thanks for the manual. Got it running without the choke tonight. Took a rip around the neighborhood. Needs a few minor adjustments including a sticky throttle cable. Just about got the neighbors fence. Going to take for a spin around Keho Lake on Sunday with the dogs. One down two to go. Many thanks for the help.
    • By BillR94
      Thank you for your time
      Bill
    • By Jason39
    • By middlebrookgt
    • By C2INS
