I bought a couple K&N air filters for our KQ's. Do they need to be oiled right out of the box? There are no instructions telling me yes or no. I do have a recharge kit if needed.
Thanks in advance.
Thanks in advance.
Yep oil them !! I only use K&N oil and cleaner !!:yes:
I've heard several different answers so finally went to K&N directly. My filters are pre-oiled - here is K&N's direct quote from email:
"Almost all K&N air filters come pre-oiled and ready to use. The filter oil we use is red. A new oiled filter will appear red-pink in color. Some crankcase vent air filters come unoiled, however, they come with a small packet of K&N filter oil so they can be oiled before use. There are also a limited number of filters with specialty uses which are not pre-oiled. These items will be clearly marked as unoiled."
    • By Martin82
      Hello to all,
      Im looking for a main wire harness for Polaris sawtooth 200,
      Thanks for info
    • By BillR94
    • By BillR94
      Thank you for your time
      Bill
    • By fixitforfree
