Any Replacement Headlamps Brighter Than Originals Available. Need Replacements And Unable To Locate Anything But From Dealer. Oem's Not Bright Enough.
    • By Elk
      2002 Polaris Magnum 325
    • By Shorty51
    • By middlebrookgt
      Hi All.  I introduced myself some weeks ago with my 2006 LT-F400F that needed a list of repairs including replacing the cracked generator cover.  It is back together as of last night and cranks up, idles and revs high pretty well.  Needs some fine tuning and stop backfiring at stop.
      The big issue is it will not go into gear.  I reassembled the insides with help from y’all’s posts.  The transfer selector moves from H-L-R, and the foot shifter moves thru the gears and finds neutral easily enough.  Before I tear it back open, the  transfer selector on top does not move as far as the repair manual says.  The diagram shows the shaft moving something like 40 degrees between L and H and 50+ degrees between L and R but it doesn’t move that far even though it finds the indent areas and moves well.
      Could this be the problem.  I aligned all the dots on the shifter gears inside and it appeared to not be binding anywhere.  I do hear the gears touching when I shift like they are trying to engage, but zero movement from the ARV
      Are there better/bigger photos somewhere that would allow me to be confident I included all the washers and bushings, etc?  If I had any doubt on parts that were laying inside after the cover broke then I purchased replacements from online stores.
      TIA for any input or feedback!!  Pics are from when I first took the generator cover off.
    • By Johnfj44
      The stock driver seat cushion is separated at a seam. I took the seat apart and found that the material has torn and cannot be re-stiched. I'm trying to find a replacement seat. Any suggestions? Hoping for a used seat but couldn't find one on Ebay.
