I need to put new valves both on intake and exhaust side bc my valve lash clearance was 0. In order to put new Valves in, can I use old shims or do I need new ones? New springs also?
Have U tried adjusting them first ? With new valves and seats u will probably be wise to pick up a shim kit !
I did try to adjust them, they were off by a lot and the intake valve keeper broke off which damaged the valve stem. So I got 4 new valves just to be on the safe side. The stock ones aren't as durable I've read. Got kibblewhites
Isn't the valve lash adjustable on that model?
Yeah I suppose so. Just gotta remove the shims and add diff sizes.
    • By carkivey3
    • By JMSwed
      Hi EVERYONE
      New member here
