Similar Topics
By quadcrazy
QUADCRAZY NEEDS YOU!
By mike91
I’m just wondering what year bike i got? it seems the vin has been rubbed off i got it from a auction here in Australia engine starts but seems has a dirty carb wont idle well
and also has a problem I put it in gear and makes a grinding noise but does not move it the neutral light goes out but then when I change gear it grinds more in the higher gears as well I’m guessing the differential is stuffed so wanting to buy new part for it will start the pull down next week
this is the first bike I have worked on used to dealing with cars
By ATVNetwork
news A powerful trail machine ready to tackle the hardest adventures.
Polaris unveiled the 2021 Sportsman 850 Trail Edition ATV with factory-equipped enhancements to tackle the roughest terrain. View the full article
By ENG243
Hello
I have a 1994 Kawi Bayou 400 which had been running well until it sat for about a month. I left the carb dry while it was park and the temp had dropped below 0C in this time. Pulled it out last night to go for a ride and it fired up just like it should but noticed when I started to head down the road I could hold it to the bar and it didn't seem to accelerate. Lower gears weren't as noticeable but 4th and 5th it just seemed to have no acceleration and half or full throttle made no difference. if I tried to go into 5th gear with any throttle it would stall. I turned around and just poked home very slow and it seemed to stay running but this was between 15 and 20 km/h max.
I have taken the carb apart and it appears to be clean and nothing stood out on inspection to have dirt or ice. Is there something I should dig more into?
I have checked the plug and it appears to be sooty with easily rubbed off carbon. I plan to get a new plug today and test.
compression with the throttle wide open is 175 psi.
I have opened the drain plug in the exhaust thinking there could be a mouse in the exhaust or something but no difference.
I do find the engine is tickity compared to my 2000 Honda but I am not sure if this is just me looking for issues or if it has always been this way.
If anyone has any insight I would appreciate it.
In the last 6 months I have done new oil and filter ( mystik synthetic)
new Peak RPM CDI
I have noticed the fan comes on more often with the new CDI, could this be a program thing?
Mike
By Admin
Looking for Kawasaki ATV VIN (Vehicle Identification Number) Number Decoders? Once you find your ATV VIN number off the tag on your Kawasaki ATV, you can go to all kinds of websites that have VIN Decoders available. The best ones are backed by the Kawasaki ATV manufacturer, however there are plenty of aftermarket Kawasaki ATV VIN Decoder websites on the web. This topic will stay pinned and if you find any to add, please do it with a reply.
The following Kawasaki ATV VIN Decoder websites are available where you can just enter your VIN number and it will shows you some of your ATV model details:
CARFAX https://www.carfax.com
