Theres big changes
The trails I called stealing wood trails that I have posted videos of is now being pulp wooded. Some man from Fl. bought all the land and is clearing it off. This can be bad or good I don't know yet. It depends on how much cleanup they do! On the + side it's going to expand our riding area and we have been told it's ok to use it for riding it should triple our riding area. But first I need a battery.
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By mga
    • By mga
