Good Day, just bought a 1988 Big Bear 350 and am missing the bumper - will a bumper from a 93 with the holes in the front fit up directly? Please see the attached pictures of the bumper for reference. any assistance would be appreciated. Thanx !
I've a thought, don't know if it's worthwhile but... Has anyone used any sort of rubber protectant on their boots. I'm bringing back an old machine that sat in the field of lost dreams for years. The boots aren't ripped or dry rotted but I would like them to last a while.
Thanks for your thoughts.
Having problems with the battery draining while riding. It has a new battery, it does have eps, a lightbar and a winch. Can ride it for an hour or more just fine, but eventually the battery runs down to the point it can't keep up with fuel injection and it'll sputter, limp, and die. It also throws codes for the throttle position sensor. I'm not sure if that is related or not. Any ideas?
Hi,
New to ATV repair but willing to learn and get my hands dirty.
We start the atv and even with a good battery, it will drain it very quickly and eventually the atv shuts down. Checking the battery afterwards shows significant drain on it.
Would this be a shot alternator? Some electronics module?
Thank you kindly. Just need to be pointed in the right direction and then with a repair manual will get to it.
Cheers
