stock piston size
bighoss
ok so pertty much he just made it a true 250 then and it still got room bigger if and when it needs it i should get a few years out of it before i have to do the top end agen or should i get longer i always run my 2 strokes rich
Edited by bighoss
    • By Drillbit
    • By p5200
      Can someone please tell me what size socket I need to remove the valve cover? Thanks! 🙂
    • By prdicon
      South Florida.
      How much it worth?
      Pros: looking decent.
      Cons
      No brakes.
      Front wheel bearings are shot.
      Idles, but sometimes will shot off. Most likely when cold.
      Gas smell and little bit steam in the air filter box when I started it.
      Display screen won't work.
      Tires are dry with cracks.
      Not sure if has title, I will check and update.
      How much do you think it worth?
    • By FalloutBoy
      Hello everyone I'm new to the forum.
    • By Dan Kroes
      Does anyone know what size wrench I need for the middle axle jam nut on a 2001 Polaris Sportsman 500 6x6? same part used on rear axles of these models.
      2000 INT'L BIG BOSS
      2001-2002 INT'L BIG BOSS 6X6
      2002 LUH 6X6 P
      SERIES 10 PTV 6X6
      1998 SCRAMBER 500
      1998-1999 SCRAMBLER 400
      2001 SCRAMBLER 400 2X4
      1999 SCRAMBLER 500
      2001-2002 SCRAMBLER 500 2X4
      2001-2002 SCRAMBLER 500 4X4
      2002 SCRAMBLER 500 4X4 FREEDOM
      1999 SPORT 400
      2000-2008 SPORTSMAN 6X6
      2005-2007 SPORTSMAN 6X6 MV
      2000-2002 TRAIL BLAZER
      1999 TRAIL BLAZER 250
      2002 TRAIL BLAZER FREEDOM
      2000-2002 TRAIL BOSS
      2001 TRAIL BOSS 325 SE
      2000-2001 XPLORER
      2001 XPLORER 400
      2002 XPLORER 4X4
