so what is the diff between them
Not sure on that !:unsure: I do know 85-86 motors are different than the 87-92 when they went to the powervalve motors (exhaust valve ) i built a 88 that I have posted on my page so I had to learn alittle bit about it !
lol i did found out on wiki that it has a 70 mm stock bore and the guy i got it from put a 70.55mm piston so what did he go over stock 10 or 20 over cant fig it out
Edited by bighoss
ok so pertty much he just made it a true 250 then and it still got room bigger if and when it needs it i should get a few years out of it before i have to do the top end agen or should i get longer i always run my 2 strokes rich
Edited by bighoss
    • By Atomusthenes
    • By bigbell
      Does any know what the stock jets are in the twin peaks?
      I bought the bike with a pipe on it and want to go back to stock setup.
    • By Joeguy
      So i bought a chinese carb and in messing around still trying to get it to run right i figured id pull the spark plug to see if it was running rich, well it was definitely but also i have a nasty mark on the strap (i think thats what its called) that looks like the piston has been smacking it. I never actually pulled the plug because i had it running for a second on starter fluid when i first bought it and was just stupid and figured whatever was in there was good. The part number on it is DPR7EA, which is similar to what is called out for in the manual but i assume the little bit off that the code is means it must be a bit longer or something. Unless the plugs are made like this, but i can pretty easily see that metal has been pushed away from the area of impact. What are the odds that my piston is trashed now you think? It does still run just not well due to carb issues but thats a whole other problem.
      Actually i just took a second to google both plugs and it says the reach is the same its just different resistor values and gap size, so maybe the bigger gap is why its hitting. Either way the actual one for it is on the way and i hope it just didnt do to much damage. Wish i woulda just went over the whole thing like i normally do with this stuff.
    • By Kibblesnbits
      Didn't use a ring clamp cause I never needed one with my Hondas but the skirt has a weird shape on the 96 KQ300, anyways I hand cranked it twice and that was enuff I guess, I had to send it back in again. Another 200 down the drain, thought I'd share.
    • By Ypner1503
      Hello and good morning I have a 1987 250 quad racer big carb and engine built . Other day I was driving it it popped and it died on me so I towed it home cuz I didn't want to prevent any more damages try to start it when I got home she backfired and kicked back hard. Need some help if anybody can help me out thanks
