Hi, can anyone help me with starting my quad 2000 model trx 350. unable to start as cant get neutral light to show. even when its in neutral it wont start. goes into gear well and runs well once it has started. It started playing up last week I could fiddle with gears and get it back again, but its not coming up at all now so I cant start it. Any ideas Jon
there is a single wire for the neutral safety switch. my yamaha is located behind the motor on the transmission and it will look like a temp sending unit or oil sending unit from a car/truck that has a tab for connection. more than likely there is a bad spot in that wire. you just have to trace it and make sure its connected well and no breaks in the wire ...
    • By Mister907
    • By Jdeaton011989
    • By toe420
