I have a 1996 kodiak 400 and the only time my tail light is working is when my lights are on. I have replaced the bulb and still no brake light or running light comes on without the head light being on. It does not come on when I use the foot brake or hand brake either. any ideas out there as to what my problem might be? Thx for the help!!! corkey
well I replaced the bulb that was in it with one just like it, maybe the people I bought it from had the wrong bulb in it. what is the correct bulb to use if I may ask? Like I say not even a running light is on. It is supposed to be on at all times isn't it?
    • By vaneleus
      any ideas how to correct
    • By quadnut20
      Just picked up this 2025 Kodiak 700 esp and was wondering if anyone has any suggestion on up grades i should look into  ?? I did a EPI clutch upgrade and put bigger tires on it but want to do more !!
    • By Adamb2025
