Hey Guys
I've got an 05 Grizzly 660 it's got a jet kit and k&n air filter installed it also had a hmf exhaust but i took it out cause it was just to loud it runs great untill it's under heavy load
when it's under heavy load it sputters like the limiter kicks in
if I hammer on all the brakes and then push on the throttle till it's full out then it starts to sputter going up hill and in mud
it does it in HI and in LOW gear
what could be the issue
thanks in advance for your help
Hey Guys
does it run ok tho with the hmf??
Cos if you have the std muffler back on it will be too rich now??
It was already installed with the HMF and yes it ran awesome so maybe it is getting to much fuel there is a dj160 main jet and needle is set to middle clip
      Hi everyone, first and foremost, I want to thank everyone for all the help I've received. I am so glad I found this community. I also wanna apologize if I'm spamming the forum, I come up with questions as I go, I guess lol. So when I got my Recon, the air box was missing the lid, held together by zip ties, and the filter was ripped and nasty. I have since ordered a new air box assembly. It comes with everything: the box,  lid, and filter ( the insert and the foam), and all the hardware necessary. This is the first time I've seen a metal filter inside a foam filter lol. However, my question is, I have read that you have to oil these filters? Every time I read it, it was always skimmed over, and I could not remember where I had read it. Is there a certain oil needed for this? Is the filter washable and reusable? Do I just stick the filter in oil, lol? Sorry if it sounds like a dumb question. Thanks in advance, y'all!
    • By marlon smith
    • By kevinohio
    • By Louznmemind
      (Question is at the end if you want to skip my blabbering) I got this unbelievably well taken care of Grizzly 350 in for a carb clean, it belongs to an elderly couple that bought it brand new in '07. Apparently whoever has been doing their oil changes for them never checked the air filter..
      Obviously it got debris in the carb, it would still run but only idle with slight choke. I've taken it apart and cleaned it, have new o rings, gaskets, etc. As far as the mixture screw is concerned, I'm assuming I obviously need to remove the plug. I'm mainly a lawn equipment guy, I've worked on slide carbs in the past but never an unmolested one with the plug still intact. I hate to mess with it as the carb had very little debris but I'm sure the o ring needs to be replaced at minimum. Finally, the question: what's the best way of removing the plug? I DO NOT want to mess up this carb..
      My 2004 Yamaha Grizzly 660 seat is a mess, torn up, cracked, and I have been duct taping it for a while.  I bought new vinyl for $35 and need to do it one day. A new seat used to be well over $250 but now its under $100 so I couldn't resist. I got it on ebay with a 10% off coupon for $85.05 plus tax. https://www.ebay.com/itm/146040022154
      In case anyone is looking for a new seat for their Yamaha Grizzly 😁
      I saw it on Amazon as well for under $100
