Okay so I need a little help
just picked up a brand new 2012 yfz450 carb model
being that it was a left over I thought my cutting out issue was bad fuel
but even after draining the tank and putting fresh gas in it
after riding for about 20-30 min in the trails
if I hit the throttle wide open it cuts out bad (doesn't die though)
it won't even climb hills
and the one time it was so bad my buddy beat me on a stock 300ex
my yfz is completely stock
no mods at all and I have tried taking it back to dealer
but since it mainly is after some trail riding
they can not replicate the problem
someone plz help
I've only been able to ride this for one tank
of gas being its running like chit and have to turn home at big hills my buddys chit quads climb right up
Edited by quadnut20
someone plz help
Clean that carb out !:yes: I bet there something in there ! Why did u get the fuel injection model ??
I had the same issue and took it to the dealer multiple times and they also couldn't replicate the issue. The solution I found was to take off the Air Box cover...the issue is that there isn't enough air. If that works then you can purchse a different filter like a bolt on one that doesn't require the air box cover. I can find the one I got and if that helps, but try to take the air box cover off and see if that does the trick. Good luck!
    • By quadnut20
    • By buriedpast
    • By Jdeaton011989
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By tflack500tbx
      Background,
      Any Ideas?
