History lesson...
The History of the Middle Finger
Well, now......here' s something I never knew before, and now
that I know it, I feel compelled to send it on to my more intelligent
friends in the hope that they, too, will feel edified. Isn't history
more fun when you know something about it?
Before the Battle of Agincourt in 1415, the French, anticipating
victory over the English, proposed to cut off the middle finger of all
captured English soldiers. Without the middle finger it would be
impossible to draw the renowned English longbow and therefore they would
be incapable of fighting in the future. This famous English longbow was
made of the native English Yew tree, and the act of drawing the longbow
was known as "plucking the yew" (or "pluck yew").
Much to the bewilderment of the French, the English won a major
upset and began mocking the French by waving their middle fingers at the
defeated French, saying, See, we can still pluck yew! Since 'pluck yew'
is rather difficult to say, the difficult consonant cluster at the
beginning has gradually changed to a labiodentals fricative F', and thus
the words often used in conjunction with the one-finger-salute! It is
also because of the pheasant feathers on the arrows used with the
longbow that the symbolic gesture is known as "giving the bird."
IT IS STILL AN APPROPRIATE SALUTE TO THE FRENCH TODAY!
And yew thought yew knew every plucking thing. _,___
    • By Jd101506
      Hi all!
      I've got a 1988 LT4WD that I am working on.  It sat for almost two decades in a shed, so I replaced both the carb and the fuel pump (Pump was rusty, carb was ok, but had a pin hole in the bowl itself?).  Now, I went el cheapo and I replaced BOTH with Chinese aftermarket Carb and Fuel pump.  Now is where it gets confusing:
      So I did this SAME thing on my other Quad, a 1988 LT300E.  They take the same PN carb, and a similar fuel pump, (One has a 90 degree bend in the vacuum port).  I've been battling the four wheeler a bit with some electrical issues, but I noticed that at idle it runs GREAT when I gravity feed fuel from a burp can into the fuel bowl of the carb... But as soon as I put it on the fuel pump from the tank, it idles EXTREMELY low and smokes a little.  To me, this indicated that the carb itself was running rich.  I adjusted it a little on the LT300e, but I could never seem to get it right, it still will slowly die at idle when warm, but ironically if I CHOKE the motor, it'll start up and run.  I dont know if this is because the RPM increases?  But the quad will run around the yard great at RPM and then die at idle.
      Now, the LT4WD.  I ended up with a faulty fuel pump for my second (I think the spring isn't seated inside as I can hear one rattling around) so when I installed it it WOULD NOT pump fuel.  So I ended up swapping the LT300 pump onto the LT4WD.  Boom, pumps fuel.  I put it all back together and got my tires on.  I ran it around my yard and it exhibits the SAME symptoms as the LT300e!  It will run around at RPM, but it will not stay running at idle, it drops realllllly low RPM and will start smoking a little as if its running rich.  Again, when I ran it with the fuel pump OFF I didn't have this issue.
      In my head I'm thinking it would be a mixture screw OR float issue... But the mixture screw doesn't seem to help me on either, and the bowls are not over flowing (I checked both overflow lines).  Is there something I'm missing here thats obvious?  Is there a vacuum line or something I missed? Maybe some configuration or something I missed? I reviewed the manual and nothing stood out to me.
      Conclusion:  Two different Suzuki fourwheelers, two different carbs (Both are chinese Ebay carbs) that BOTH run well when I mainline fuel from a drip can INTO the bowls, BOTH do not keep idle and seem to run extremely rich as they run great at RPM but slowly die at idle.  Adjustment screws, idle screws be damned.
      I ended up ordering a new Suzuki OEM fuel pump for ~90$ just to have it and see if it makes a difference.  Any advice here though would be SUPER appreciated!
    • By 86096
      I have a 1985 Suzuki LT230 GE quadrunner.  It has been stored in a shed for at least the last 15 years and has very low mileage.  Although the tires look and feel great... should I consider changing them since they are 38 years old?  I don't intend to ride to far or too fast but I don't want to have to walk out of the bush.  Any input would be welcome.
    • By 8AV8
      I just purchased a 2004 Polaris Sportsman 700 EFI. While riding today I noticed the throttle lever
      was getting hot, not just warm but too hot to touch. I’ve never encountered a problem like this before.
      I have a service annual ordered but it won’t be here for a few days.
      Any help would be greatly appreciated.
    • By jatho
      Does anyone know what year they stopped producing the King Quad 300? - particularly in Australia and New Zealand
      What were the design changes?
    • By remnar
      New member here,
      I have searched here and other places and have not found an answer to my problem.   As the title says I have a 2014 420 Rancher that recently started having an issue were the revs before the clutch engages.
      I have checked the oil level (per the service manual) and replace the Valvoline ATV 10w40(less than 5 hours) with 10W30 GN4 for good measure. I have used the "pin" method to pull a DTC.  I shows a 8-1 which is a TPS error.  This makes some sense, as if the computer doesn't read throttle position correctly, it could have this symptom. I have checked the source voltage, and tested the TPS off the quad with a Fluke and a power supply at 5v.  It is smooth and does not seem to be a bad sensor. I am confused by the DTC, because the PS light blinks the code, not the check engine light.  However, there are no PS codes of that value.   This condition appeared after a couple days of driving in the cold (~32°) and driving though some water/bogs.
      A couple questions.  First has anyone seen this issue, and do you have any suggestions? I have followed the troubleshoot right up to the point of replacing the ECU, which I don't seem to have one on the shelf :)
      Second, anyone used a OBDII reader with an a 4pin adapter to pull codes?  If so, what system do you use?
      Beyond the rev issue, the quad runs and starts perfectly and when it decides, the clutch grabs tight (no slipping)
