ATV tires... how old is too old?
86096
Go to solution Solved by 86096,
I have a 1985 Suzuki LT230 GE quadrunner.  It has been stored in a shed for at least the last 15 years and has very low mileage.  Although the tires look and feel great... should I consider changing them since they are 38 years old?  I don't intend to ride to far or too fast but I don't want to have to walk out of the bush.  Any input would be welcome.
I'm sure that for a whole lot of woowser reasons we are meant to say not to use them.. but I'd pump them up gently, with a hand pump as they recommend since they take so little air or pressure, and see what they look like. Unless they had a lot of small cracks I'd use them.
I would run them also, it not like they are highway rated anyway, rubber does get harder and slicker as it gets older, so if you are doing a lot of rock climbing and hitting stumps you might reconsider, but that kind of riding plays havoc on new tires also. So yeah i would run them, but i wouldnt try to break any speed records.
  • Solution
I'm not gonna do anything crazy on this ATV and I was pretty well decided that I'd run the tires as is and see if they look like they'll hold out but if anyone had a really compelling reason not to I would look for new ones.  Thanks for the input!!!
I agree with others, I'd air them up and try them.  Maybe go for a quick ride for 15 to 20 minutes then check them out.  If there are any cracks I would replace them.  I just replace a set of tires on my 05 triton atv88 trailer as they were cracked in several spots and sidewall.  Obviously this is a bit different with loads and highway speeds but they were almost 30 years old.
  • Similar Topics
    • By 97kingquad
      I have been rebuilding some ATVs in my spare time and teaching myself along with the help from the internet how an engine works and getting bikes running again is quite enjoyable. I even built an arctic cat 300 4x4 from two parts bikes the had seized motors and missing parts. It was pretty enjoyable.
      So I am now working on a sazuki quadrunner 300 1992 which had a whole list of issues when I got it. I have fixed almost everything I need to in order to get this bike running. But something is going on inside the head or crankcase.
      I had to replace the timing chain because it was very stretched due to the previous owner.
      What the issue was, the timing chain was off the sprocket inside the engine due to it being stretched it slipped off. So the previous owner rebuilt the top end thinking it would fix it which it may have temporarily, but when doing so they welded an extra inch onto the tensioner to hold the chain tight. Which as you can imagine caused a dozen other issues.
      So that stretched the chain to the point where I could remove the cam with the tensioner in.
      It beat the sliders all to hell. Destroyed the cylinder housing and obviously ruined the tensioner.
      I didn't realise all of this until after I rebuilt the engine.  I noticed wear where the timing chain runs through the cylinder. I found the cam had no retaining chair, or clip whatever you want to call it so the cam was beat to sh** also. It had almost an inch of play side to side.
      So I pulled the head off of my parts bike and fixed all of it. Then put it together and went to pull it over and found it was not on the sprocket (this is when I realised that all that damage and the welded tensioner was because the timing chain had been off the sprocket)
      So I pulled the stator cover off and pulled the flywheel (which I should add to get at the stator cover I have to remove the rear tire and a arm as well as remove the bolt through the front of the engine. And the exhaust system has to be removed to pull the cylinder as the exhaust guard is bolted to the side of the timing chain tensioner. Stupid setup. Glad the king quad doesn't have that.
      So I got everything apart and the flywheel off. New timing chain (nice and tight now) put the head back together and flywheel but it is quite hard to turn the engine over. I can but with difficulty. When the valve cover was off it seemed to spin much more freely. Before I tear everything back apart and start again any ideas on what it is?
    • By GTX-Racer
      I am looking for a PDF version of a manual for a Suzuki Quadrunner 250.  I am not sure of the year, but believe it is a late 1990s model.
    • By GTX-Racer
      I recently purchased a 1998 Suzuki Quadrunner 160.  It is very clean and in good condition for it's age.  I am rebuilding the carburetor and looking to do some maintenance.
      I am going to change the oil, which is simple enough, but after reading the manual there are many adjustments that are needed when the oil is drained.  Does anyone have any advice on the valve clearance or clutch adjustments?  Both require the oil to be drained and the engine at top-dead-center.  Anything else that I should do while it is in this configuration?
    • By GTX-Racer
      I am looking for a front battery cover for a Suzuki Quadrunner 250 (year unknown).  It has the headlight on the handle bars and no speedometer.
    • Get More For Your Device
    • By 97kingquad
  • Similar Tagged Content
  • Gallery Images
