Ok..I have the key for main ignition..for some reason, my push button isn't working..I have replaced starter solenoid, start circuit relay, new battery..when I turn the key on, I have 12 volts on the right side of my solenoid, not getting any voltage from the small blue/white stripe wire on the bottom of relay..assuming may be problem with one of the safeties..I can pull start everytime, I can jump solenoid with screwdriver, wrench, etc, and it starts everytime..so I just want to run a new aftermarket push button switch..my question is exactly how to do it..would I just run one wire the the small red/white wire on the bottom of solenoid, and run the other wire(from push button) to the small blue/white wire on bottom of solenoid?..I plan on using 14 guage wire, and I ordered a momentary , waterproof, push button..I plan on just drilling a hole between the key switch and reverse knob and installing it there..would like my e start working before winter hits
you would run a wire that is hot when ign is on to your switch then from switch to your solenoid then run a ground wire to solenoid
Edited by gangle04
    • By realpilot
    • By logray
    • By OldATVowner
