My daughter got a scare her and her friend were riding and the cvt belt went on my prairie and it went into limp mode and shot flames out the pipe when it backfired and you could smell the belt where it got hot. I went to pull her home and she thought the quad was going to blow up with her setting on it.
    • By quadnut20
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By quadnut20
      What a great week to ride !! Im semi retired and plan on riding this week !! Who else is riding and where !!
    • By HighPlainsIT
      My son's trying to get a 2003 Prairie 360 running. Over a year ago, he'd rebuilt the carburetor using a SHINDY 03-112 rebuild kit from JT Cycle & ATV, and it was working fine; however, when it wouldn't run recently, he took the carb apart and the jet needle was rusted in place. He cleaned that up as good as possible and replaced the jet needle with the old one that wasn't rusty. Now, he can only get it to start about 1 out of 5 tries, and when it does start, it won't run unless the choke's on. The spark plug's good and is sparking. It has compression. Any ideas on what he should try next or look into?
    • By mikeexplorer
