Ok I have a bayou I have been working on runs at idle once the throttle gets to about 40 to 50 it falls in its face I have done the following
Cleaned carb SEVERAL TIMES
Compression test - good
Leak down test - good
Adjusted the valves - good
Checked timing - spot on
Coil test - good
Stator test - good
Crank sensor - good
Checked the crank key - good
Cleaned air filter cleaned gas tank sprayed carb cleaner around boot head and cylinder
All good
Tested carb float level - within spec
Only thing I noticed is there is a bunch of dirt and dryer mud in all electrical conections that will be getting cleaned this bike is all stock I'm just pulling out my hair trying to get this thing to run right
