I'm working on a 2007 Outlander 500 here with a no start issue. bought it from a guy with a bad crankshaft so i replaced it put it back together and now it wont start when i press the green start button i can hear the relay click and the fuel pump prime i have checked all fuses relays and diodes they are all good also noticed the injectors are not firing the starter solenoid is good I checked by running jumpers to the small control wire terminals one to ground one to positive and it turns over and can get it to run by squirting fuel through the intake
i have checked and cleaned all connections i have checked for codes and none are being displayed i have even tried holding parking brake and foot brake while trying to start as some have said that might work so im not sure whats going on
You prolly already checked for fuses ...but if not they could be bad.
I also was told it could have a ground issue.. So check and clean the ground wires
The on/off switch could also cause it not to start and run..
    • By Mister907
    • By Jdeaton011989
    • By Brent Wright
