So far its coming along. Installed a 99 cr125 motor in the frame. Have all the motor and coolant mounts welded in. Working on installing a link in on the swingarm. Putting a trx450r shock and linkage on. Going to be running a yzf450 hydraulic brake on the rear. The front will be getting trx250r two piston calipers with hubs and spindles. The back end is taking the longest so far.
  • 3 months later...
    • By vaneleus
    • By toe420
    • By Olchap
      Thank you,
      Olchap
    • By RussB
      Has anyone found a rebuild kit or an aftermarket replacement for the original which costs 500.00 US dollars?
    • By Asand211
