2007 Kubota RTV 1100 4X4 Diesel only 66 hrs (san antonio)
(This Ad is from QUADCRAZY Classifeds, click "More" to find out how to contact the person who placed this ad.)
Gently used 2007 Kubota RTV 1100 4 wheel drive. Only 66 hours! Heat and air conditioning. This Kubota RTV is in absolutely perfect condition and, in realty, is not even broken in yet. Drive it around the farm or ranch, or play with it off road! Very fuel ...
More...
    • By mga
      I have to replace all 4, how much is involved?  Will they slide out of the front yoke? Or, do the boots just slide over the wheel end?
    • By Werewolf
    • By tryn2hrd
      I have a rancher 420 TM that since i bought it has a cold hard shift problem beyond a doubt clutch is not releasing by shift lever. After it gets good and hot it shifts ok. Tried preloading adjustment screw clutch releases and shifts smooth but slips. Have had the clutch out and apart twice for inspection and didnt see anything wrong. Any tips will be appreciated. I've ran out of things to try instead of throwing new parts at it.
    • By Uglyside38
      Anyone have experience using Meier aftermarket plastics? OEM ones are shot on my quad I'm restoring and I have them "Frankenstein'd" for now...🤦🏼‍♂️😬
      Just curious on opinions on Meier as that seems to be the only place I can find any type of replacements. (And they're pretty pricey!)
      I bought this Eiger about a year ago it has been my runner while i worked on my other projects, except today it wouldnt crank, i suspect it is the  petcock not letting fuel through. When i bought it it had a multitude of problems, but i just ignored those and rode it any way, put it on the back burner while i worked on my other projects with more serious problems, like stuck engine ,wiring harness ripped out, and wheels locked up. Got those all sorted out and since it wouldnt crank today decided it was time to refine this one. When i got it it had a bad Non OEM carb replaced it with a cheap aftermarket until i could find a descent priced OEM to rebuild, and have been riding it ever since. It also had a bad petcock, would only run on prime, neutral light didnt work, no brakes, which are a luxury anyway, but as im getting older luxurys are nice to have, so i guess i will fix those. I paid a little more for this one, $800 but he wanted $1500, because it ran and moved and most things seemed to work, and it didnt smoke, even with the bad carb. Generally 500 is my limit for a non runner, since this one ran i upped my limit a little. So i got it out of the shed before the mice got in it for the winter and started going over it today.
      I would never buy a new camouflaged one because of what you see here, and it almost stopped me from buying this one, but it is what it is, not much i can do for that now, they did look nice when new, i am toying with the idea of replacing the plastics while i can still get them, but am not there yet, expensive.
      I think the snorkel has got to go its not hooked up anyway. Looks like a perfect mouse house.
