i would go on ebay to find parts rather than a dealer ... 250 Kazuma Seat | eBay
its hard to find a decent chinese manual ... sometimes the dealers will just photocopy what they have or give you a link. there should be a serial number maybe on the neck where the handlebars go down the tube in front of the motor or by your left foot sitting on bike on the frame rail stamped into the metal ...
there should be 2 nuts holding the carb to the rubber manifold, those come off as do the gear clamp (just loosen it) for the air box. once done, you should be able to wrestle it out the side. it will be easier to do if you remove the gas tank first. there will be 4 phillips screws to remove the bowl.
  • 4 years later...
    • By cavry
      Cavry
    • By flyinbrian365
      Factory service manual
    • By flyinbrian365
    • By flyinbrian365
      What's Covered:
    • By flyinbrian365
      What's Covered:
