2002 Honda 400ex - Won't Start
terry001
Hello fellow riders. new to this. I have a 2002 Honda 400ex. Just picked up. It will not start. Owner said it was running a few days ago.(LOL). Quad was all together when picked up. spits and sputters and back fires.
This is what I have done.
#1-checked fuel--OK-Spayed starting fluid--no start
#2-check spark--OK
#3-check compression-100-110psi
#4-Pulled valve cover off and check timing. Timing good. top dead and cam at two lines even with head.
#5-doubled checked timing again-OK
#6-6 of 8 bolts holding valve cover stripped.Don't know if this affects anything.
#7-decompression seems to be working-only rotates one direction. Manual dosen't seem to say much on it works.
Any advise would greatly help
Eger rider
i would take the carb off and give it a really good cleaning, check the needle and seat at the float and make sure needle has a nice point ... i would remove as much as i could with the inards and clean thoroughly using a stripped twist tie to get everything cleared out ... lots of spray carb clean and if you have a compressor to blow it all out, all the better ...
Thanks for the response
I cleaned the carb pretty good. I forgot to mention that I pulled the quad behind the truck and still no start. I'm a pretty good tech but damn this thing has got me stuck.
    • By exalrod
      Hello All !
      Could anyone help with this?
    • By pitts
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By newguy024
    • By NZrider
