Arctic Cat 2005 500LE automatic. My fuel pump recently started making a "ting, ting, ting" sound. Is it going to fail? The machine runs just fine, but I would hate to get stuck out in the boondocks when this quits.
    • By tepin
    • By randyoct
      Will the top end of a 400 fit a 366 the price is so much cheaper
    • By spigmef
      I bought a 2008 arctic at 366 with 120hrs. When i red line it in neutral is smokes blue a lot. When I put it in high range it has problems getting over 35km/h. I bought it and had to clean the carb. It ran ok after i cleaned it. Not I have this problem.
    • By ath1981
      Got a 2011 425 EFI. It eat 2 belts, so I replaced the drive clutch assy, rollers, spacer and movable face. Put on a new belt and after 30 min of riding, it eat another belt. any clue what can be causing this?
