(This Ad is from QUADCRAZY Classifeds, click "More" to find out how to contact the person who placed this ad.)
For sale is a 05 450r has +2 jansen a-arms triple rate elka long travel suspension +2 tusk axel Douglas bead locks and new itp quad cross tires, motor has a 480 top end from cylinder works and a stage 2 hot cam the frame has fresh powder coat done about a...
More...
      QUADCRAZY NEEDS YOU!
    • By davefrombc
      It would be  helpful at times to have a button  where we could cont the Admin. to  make some changes to  our posts.
    • By n4cer26
      Just bought a non-running 425 Magnum 6x6. Guy said previous owner had motor rebuilt (3 years ago or so.) It reportedly ran great but recently the electric start began failing and he put a new recoil on it which he broke immediately.
      I get it home and put a new recoil on it and the pull is incredibly hard....so much so that I think I'm going to break the new recoil assembly. I also installed a new starter which won't roll it over either.
      I'm thinking maybe a hydro-locked situation so I pull the plug and the motor rolls over fine with both pull start and electric start. The cylinder was dry however.
      Checked the valve lash and it was right on at .0006".
      Checked the compression relief spring on the end of the cam and the spring was strong and keeps the metal piece against the dowel like it should. The cam lobes look good from what I can see.
      I have a small camera that I dropped into the cylinder. Could t get a pic of the entire chamber because of the angled engine but there are marks on the center piston and a couple of grooves once side of the piston top. I will include the photo.
      Anyway....I'm at a total loss at this point. Not sure how to proceed and diagnose. Would sure appreciate anyone's help who might know what the heck is going on! I was able to get it to turn over about 5 times with electric start with compression tester installed which read 145 lbs. I don't know what else to do!
       Reply
      Sent from my SM-F926U using Tapatalk
    • By Lafytafy
      my rear suspension is trashed and i dont know what to replace it with
    • By Yammy
      Can you ride your quad on the road or cross a road if your quad is licensed and registered and you have functional signal lights and running lights?
      Let me know, I'm new to this.
      Thanks!
