What is the deal with the front brakes on the lt80s? I just bought 3 used and none of them work, what is the trick?:aargh:
The pin going thru the backing plate needs to be removed, cleaned, and lubricated.
That usually helps. :)
    • By TomJulio
    • By TomJulio
    • By Olchap
      Thank you,
      Olchap
    • By Rick Shropshire
      I’m looking at replacing rear brake calipers on both of my blasters. I was told that the only thing available was a hydraulic upgrade? I’d prefer the original. Anyone?
      I decided it was time to do the brakes on the Eiger, i got it a couple of years ago and worked out all the bugs got it running good and ignored the brakes. None on it ,front or rear. Decided to attack the front first no pressure on the master cylinder and screws were stripped out on the reservoir, took the banjo bolt loose and pure water ran out, glad i didnt wast time on drilling the screws out, pads were shot also. Pulled a couple out of my box o parts. One was for right hand so wouldnt work, the other looked fine until i opened the reservoir and full of white powder. Cleaned it out anyway and tried it, only would build up a minimal amount of pressure. So no go on that one. So ordered new master cylinder and pads, so now i have to hurry up and wait.
      On to the back they are drum brakes so i knew this would be fun, 20 year old machines that have been mudded and abused for that length of time nothing comes off easily. The engage shaft was froze solid from corrosion. Getting that out is easy but you have to get to it first.
      The center nut was supposed to be 30mm but it wasnt it was 27 the only size not in my large set, go figure,
      The previous owner decided it was a good idea to JB Weld the cover on making it near impossible to get off, had to chiesel it off.
      The mounting plate was a different story, nut was tight tight tight took my biggest impact two or 3 times hammering on it to get it loose after soaking all night in PB Blaster. Got it moving along the splined shaft easily but wouldnt come off, when it got to end of its run it would just stop, ended up using 2 24 inch pry bars one on each side, past the point of being gentle and it finally came off.
      Got to the drum and it came off easily a little suprised at that, it was full of mud and rust, i knew it was going to be bad because there was a snorkle on it when i got it, never buy one with a snorkle, they are highly abused to the machines limit, but i got it cheap .
      Finally got in there and no shoes left and a complete mess.
      Lots of mess to clean up.
      Got it looking a little better.
      Lots of cleanup later! Waiting for new parts.
