I have a 2003 trx400ex missing the neutral switch wire the one that goes from the engine to the light green on the harness can I replace it with just any wire
I am also missing the neutral light can I just plug the black and light green that go to the light together
Edited by Jonah27j
never mind I figured out It runs without any of it hooked up I just had a bad connection at the fuse she runs good now warmed up a couple times in the gouge going to the farm this weekend to break her in
    • By OldATVowner
    • By wilmpie
      hi everybody
      I have a kymco mxu 250 automatic from 2006 250 cc  that keeps going forwards or backwards when i shift backwards or forwards an then shift to neutral .
      if i shutdown the motor and push the quad and restart then its in neutral and don't go forwards or backwards, i already checkt if my motor is running good stationairy .
      what can it be or what can i do to fix this?
      thanx in advance
      p.s. Sorry for my bad english it's not my first language.
    • By Rockbottom
      any ideas how to correct
      thanks ahead
    • By digrig
      Hey everyone,
    • By T37Mark
