My Arctic Cat starts up fast and will rev up great. But after about 10-15 seconds. It doesnt want to rev up all the way.
I put it in first gear and drove it around and it was putsying along, while attempting to rev it up and it sometimes backfire and barely get around 5-8 mphs
What could possibly be the issue?
    • By jay41198
    • By tepin
    • By Shorty51
    • By HoldenBoy
