About 3 weeks ago I traded a mc for a 2007 polaris sportsman 800 efi 4x4.
When I test drove it all worked well.
we went to some trails and my son got stuck in some mud and when I pulled him out the 4wd worked great
So a friend of mine wanted me to bring it over to see if it would pull a grader blade he had made.
we were pulling it great till it hit some real loose gravel once he started to spin I told him to engage 4wd.
he engaged it and nothing from the front wheels just rear wheels spinning.
Here is my confusions
I hear JD parts will fit some polaris 4 wheelers cant confirm for the 07
I changed the oil in front differential and flushed out and filled again still nothing
the front drive shaft is turning but front wheels arent (all 4 wheels jacked up)
Checked plugin going to front differential it has voltage.
no noise or anything when in 4wd last but could the cage be bad seems like a popular breaking point
is there other yrs that innerchange with the 07 as far as differential parts
did they upgrade this in the 07
the dealer told be there was 4 different differentials in 07 pending on what month it was built
he also told me it should hole 10oz of fluid but it dont.
I have download the service manual and will print it today but any advice suggestions would be great
thanks Mike
    • By Thekevinjb
      thanks
    • By Atomusthenes
    • By RadRob
    • By Tim Keiper
