Bought a 07 sunl 110atv from some one who got it at auction and couldn't get it to do any thing. I have no experience at atvs but i'am very mechanically capable so i figured id take a gamble and buy it for my daughter birthday. After a couple of broken wires i go it cranking again but no spark(with kill switch unplugged). After a bit I found the magneto (sorry if incorrect term)or pickup for timing trigger was in pieces. I bought a new stator for it to find that when i cranked it i could hear a tinging sound stator cover was cracked and pushing pickup into fly wheel. I replaced cover also.Not knowing what broke cover i also ran a dial indicator on fly wheel to make sure shaft wasn't bent. Now after all my research I'm at a dead end. I will tell you guys the info from my testing.
Testing cdi plug (unplugged and off) between ground and pin
timing trigger- 122 ohms
ignition coil- 0.6 ohms
kill switch- infinite
ac ignition power- 340 ohms
Also have good ground on connector too
Testing cdi plug (while cranking unplugged)
A/C ignition power- 36 volts ac
timing trigger 0.7 volts ac
Is there any way to test cdi or coil?Any help would be appreciated bought it for my daughter birth day on the 10th need to figure it out asap. Thanks to all in advance.
Read more: 07 sunl 110 atv no spark need HELP ASAP Page1 - ATV Forums at ATV Rider Magazine
are these ohm readings within spec of the manufacture? I have seen lots of those chinese bikes with kill switch and tether problems causeing no spark. If you had the mag cover off did you resolder any new wires or slice, reason for asking is maybe there is a shorted wire under mag. I myself would lean more towards a bad switch, or tethor switch not being grounded out properly.
Thanks for reply ended up being a bad cdi. Now I cant kill it with switch or handle bar switch. Not sure if it has anything to do with it but remote box was gone befor I got it. Could any one shed some light on what needs to ground out to kill motor? I thought it would be kill pin on cdi but with direct ground on it, it continues to run.
    • By joezee13
    • By middlebrookgt
      Hi All.  I introduced myself some weeks ago with my 2006 LT-F400F that needed a list of repairs including replacing the cracked generator cover.  It is back together as of last night and cranks up, idles and revs high pretty well.  Needs some fine tuning and stop backfiring at stop.
      The big issue is it will not go into gear.  I reassembled the insides with help from y’all’s posts.  The transfer selector moves from H-L-R, and the foot shifter moves thru the gears and finds neutral easily enough.  Before I tear it back open, the  transfer selector on top does not move as far as the repair manual says.  The diagram shows the shaft moving something like 40 degrees between L and H and 50+ degrees between L and R but it doesn’t move that far even though it finds the indent areas and moves well.
      Could this be the problem.  I aligned all the dots on the shifter gears inside and it appeared to not be binding anywhere.  I do hear the gears touching when I shift like they are trying to engage, but zero movement from the ARV
      Are there better/bigger photos somewhere that would allow me to be confident I included all the washers and bushings, etc?  If I had any doubt on parts that were laying inside after the cover broke then I purchased replacements from online stores.
      TIA for any input or feedback!!  Pics are from when I first took the generator cover off.
    • By Ejwill
      I rebuilt the top end on my 2007 Honda Trx500fe. It ran fine right after the rebuilt. But now when I try to crank it it blows Bach through the carburetor. I held my hand over the opening for the intake air and it blew gas back on my hand. Can figure out what happened all of a sudden. It was cranking and was able to ride it running through all the gears. Now can get it to crank just blowing gas back to the air filter. Need help again. Starting to think I should have walked away from this one.
    • By Need-help-with-quads
    • By motox88
