Make sure the jam nut is off or at least loose first, it's a 6mm allen hex, If that's rounded off you're going to have a tough time getting that sucker out. You can sometimes pound a 1/4" hex bit into the rounded out 6mm. Failing that get someone to weld a large nut onto that pivot bolt and it should come out.
    • By mehim
    • By Rick Shropshire
      I’m looking at replacing rear brake calipers on both of my blasters. I was told that the only thing available was a hydraulic upgrade? I’d prefer the original. Anyone?
    • By That229Yamaha
      Hey guys, I’m new to the forum. What I got is a 2001 Yamaha Bear Tracker 250, got it as a project on trade and the problem I’m dealing with is a “no spark” problem and been trying to hunt down the cause for two weeks. I’ve replaced the stator, pick up coil, CDI, wiring harness, ignition, coil pack, spark plug, solenoid, battery, etc. and I’m still not getting any luck. Even tried bypassing the kill switch. I also noticed two things on this quad, another CDI under the back plastic by the voltage regulator, and a blue and green wire coming from the motor behind  the foot shift, tried to hook it up but it broke off and I’m thinking the broken wire would cause it to have no spark, if not then I need someone’s help on this and wanna see if I can get spark again. If anyone knows why I have this problem, the help would be greatly appreciated.
    • By El_Guapo
      Hi folks, im working on a kazuma Falcon 250 with has the ubiquitous 3 lug 8" wheels.  have a set of polaris ranger wheels and tires that i would like to use on this little atv. they are the standard 4 on 4 bolt pattern. Any recommendations for wheel adapters to achieve this? (double whammy as the wheel track will get wider with adapters). cheers!
    • By JoeB
      Considering pulling the pin on an ARGO xplorer 570 xrt 2 up unit. Has anyone had any experience with these. They offer a pretty good sounding warranty but I don't know anyone who's got one to know if they're good about following through on their warranty promises
