    • By tepin
    • By Shorty51
    • By tflack500tbx
      Background,
      Any Ideas?
    • By randyoct
      Will the top end of a 400 fit a 366 the price is so much cheaper
    • By spigmef
      I bought a 2008 arctic at 366 with 120hrs. When i red line it in neutral is smokes blue a lot. When I put it in high range it has problems getting over 35km/h. I bought it and had to clean the carb. It ran ok after i cleaned it. Not I have this problem.
