I have a problem with a PZ19 carb (Kazuma 110). I have disassembled and cleaned it and still have a very rich running engine (black plug). I can't find any info for this carb such as jet sizes,
float height and needle position. The main jet now is #71 and float is level with bowl edge.
Any info would be helpful Thanks for any help. Cooter
Hey, thanks very much for the info 'oxidized_black'. I have a overly rich idle mixture which I can't lean out. I'm a retired auto/motorcycle mechanic but have never seen a idle mixture screw without a fine tapered end on it.
The one I have here has a short taper with a flat ending.That doesn't seem correct to me. I been looking for info on the carb or a view of the mixture screw but no luck so far. Carb model is PZ19 ser # EK04E9
I'll keep searching and post any results. Thanks again Cooter441
    • By digrig
      Hey everyone,
    • By ButchM
    • By dkgg5755
    • By Ironworker709
      I have Grizzly 700 that has been pretty much totaled out in a bad accident, but it will still run and drive good...
      Will this engine swap into any of the Yamaha UTV's like thr rhino and Viking 700's?
      Was just going to sell it as is for a engine for someone who needs one pretty cheap..but been thinking about getting a UTV for the family and maybe find one with a blown engine cheap and swap it out
      I already an excellent shape 2001 Big Bear 400 4x4 for us..but kinda been looking for a good used UTV for us and the grandkids on our property to play with
      Not sure of the year..i can't remember what year it was when i picked it up for a buddy a few years ago..he went to jail after he totaled this thing and told me to pick up a few things at his house he was renting and just keep them for myself since he owed me a bunch of money before the landlord sent them to the dump...
      The first picture is when i went and picked it up for him..second is how it is now..frame is all twisted up and plastics are fubarred..going to sell the rims and tires.they stick out way too wide on my Big Bear
    • By Sporpo
      Have a 2018 Sportsman 850 SP with factory 26x10x14 rears and 26x8x14 fronts, and it is now time to replace them. So, is it reasonable to replace all four to now be the same size of 26x9x14? Replace with radials, of course, and at least 6 ply rated. And, can a 27" tire fit on the factory wheels? Thanks for any replys...i know this has been hashed and rehashed so many times, so thanks for all replys, and, yes, this bike has had a literal ton of cash put into it just to get it running again, and still needs some tinkering, but it will be a work bike, it is not a pleasure/recreational bike like it was intended to be... LOL
